MSXVR + DATA RECORDER
MSXer
Been thanked: 3 times
Post by MSXer »
Hola!
What kind of calble should i use to connect MSXVR to a Data Recorder?
The normal cable iforcreal hardware is a DIN -8 > 3 jack MIC EAR REM
Thanx
Gianluca
Re: MSXVR + DATA RECORDER
You can use:
for EAR .. a jack stereo/mono 3'5mm standard.
for MIC .. a jack stereo/mono 3'5mm standard.
for REM .. a jack 2'5mm
References:
http://www.msxcalamar.com/catalog/index ... er=product
MSXer
Post by MSXer »
msxvr wrote: Sat Oct 29, 2022 7:45 am You can use:
References:
Great! Thanx!
the only problem is that I have found that my data recorders are broken,
and I need a repair. But that's another story... :(
