USB Stick problem
MSXer
Been thanked: 3 times
USB Stick problem
Post by MSXer »
Hola!
I have a 64GB USB stick connected to the MSXVR
Suddenly it works ONLY with the MSXVR, and no others machines (PCs, NotebooKs....) reconize it... :shock:
Is there a way to copy the contents of the USB stick (connected to the MSXVR) from my PC through the network?
Rafa
Has thanked: 39 times
Been thanked: 5 times
Re: USB Stick problem
Post by Rafa »
Hi mate.
Yes, you can connect your MSXVR to a PC throught SAMBA protocol on the host machine.
Activate samba on the PC and use mount command on the MSXVR side.
Apoligies for my poor english. It is not my mother language.
La inteligencia me persigue.
Pero yo soy más rápido.
MSXer
Post by MSXer »
Hola Rafa,
I still have windows7 and I don't know how to activate SAMBA... :?:
seems a little tricky for me :?: :shock:
MSXer wrote: Mon Jun 27, 2022 7:51 pm Hola Rafa,
This is the tutorial for Windows 10. I think that Windows 7 is not too much difference.
The description are in spanish but the screenshots are in english :?
viewtopic.php?f=18&t=71
Rafa
Post by Rafa »
Hi MSXer
efraimsangil has the best ever post to activate a user with SAMBA on Windows.
Follow it.
But if you have troubles with it, there is another solution.
Install filezilla. https://filezilla-project.org/
Its more tricky but has a manual in perfect english ;)
MSXer
Post by MSXer »
I already have FileZilla, but i don't know which username and password to put...
Hello,
@Rafa , what you want is for him to upload all the files from his USB connected to the MSXVR to an FTP site using "C:\>mount /rw b: FTP:user:password@dominio" and then download these files with the FileZilla you have installed on your Windows?
If he doesn't have an FTP site of his own, could he use msxlibrary?
As they commented, the best and most practical thing is to use SAMBA...
Saludos a todos :)
MSXer
Post by MSXer »
What exactly i would like is to be able to access the USB stick connected to the MSXVR from my PC.
Since this USB stick is only and only read by MSXVR, i would like to copy all of its content to my PC.
I also tried to insert an additional USB stick to the MSXVR and, through File Explorer, copy the contents of USB1 to USB2 but it is a very long job because it does not allow me to copy entire folders and sub-folders (only the files) and after some copied files, the MSXVR hang, and i have to force shutdown the machine...
Rafa
Post by Rafa »
Hi.
Some time ago, I use filezilla in a PC with windows to create an "ftpserver" locally on my home network.
I have to do it because I can not create a user to activate the samba protocol.
When I activate the filezilla server, I can connect the MSXVR using mount to my PC running filezilla and copy files to/from it.
I use it to use VSCode to edit an VRScript project that I was developing.
But with the improvements that MSXVR has had, that was not necesary anymore.
That was my two pence :D
Regards
MSXer
Post by MSXer »
After 1000 attempts, couldn'r solve anything...
I think l'll give up.... :cry:
