Strange message at boot
MSXer
Been thanked: 3 times
Post by MSXer »
Suddenly, at boot, I get this message:
[sda] No caching mode page found
[sda] Assuming drive cache: write through
Then the MSXVR starts up regularly....
do I need to worry? :?
Re: Strange message at boot
Did you boot with an USB Pendrive inserted?
MSXer
Post by MSXer »
Yes, i've changed the pen drive after the problem described in "USB Stick problem" topic
Ok .. no worries about this issue. Some pendrives show this text messages on the screen when the system boots.
Thank you for your report.
