persons.xml
<?xml version="1.0" encoding="UTF-8"?>
<persons>
<person name="John" >
<properties>
<property name="age" value="30"/>
<property name="gender" value="man"/>
<property name="profession" value="dentist" />
</properties>
</person>
<person name="Mary" >
<properties>
<property name="age" value="31"/>
<property name="gender" value="woman"/>
<property name="profession" value="engineer" />
</properties>
</person>
</persons>The loader code. The complex part. Not necessary to understand it at full. Just use it.
XML_Loader.pi
// XML_Loader Script
// based on
// TMX_Loader by Alberto De Hoyo Nebot
// VR-Script modifications: Javi
class XML_Loader
class Object
properties:
name = "";
type = "";
subList = [];
function _operator_delete ()
for (i=0; i<sizeof(subList); i++)
_list = _get(subList[i]);
for (j=0; j<sizeof(_list); j++)
delete _list[j];
subList = [];
properties:
TAG_NAME_LIST = "list";
TAG_NAME_TEXT = "text";
xmlDoc = null;
xmlElement = null;
subList = [];
function _operator_new ()
delete _list[j];
subList = [];
function LoadStartFromFile (_file)
_fileSize = File_Size(_file);
_buffer = Buffer_New (_fileSize);
File_Read (_file, _buffer, 0, _fileSize);
File_Close (_file);
_xmlStr = Buffer_GetString (_buffer, 0);
Buffer_Delete (_buffer);
xmlDoc = XML_Open (_xmlStr);
if (!xmlDoc)
return 0;
xmlElement = XML_GetRootElement (xmlDoc);
_num_steps = GetNumSteps (xmlElement);
return _num_steps;
function LoadStart (_filename)
_file = File_Open (_filename, FILE_MODE_READ);
if (!_file)
return false;
return LoadStartFromFile (_file);
function LoadXML(_filename)
if (!LoadStart (_filename))
return false;
ReadClass (this, xmlElement);
XML_Close (xmlDoc);
return true;
function LoadNext ()
if (!xmlElement) return false;
_xmlElement = ReadClass (this, xmlElement, true);
xmlElement = _xmlElement;
if (!xmlElement)
XML_Close (xmlDoc);
return false;
return true;
function GetNumSteps (_e)
_count = 0;
while (_e)
_e = XML_NextElement (_e);
_count++;
return _count;
function ReadClass (_obj, _e, _iterative = false)
while (_e)
_key = XML_GetElementName (_e);
_text = XML_GetElementValue (_e);
_class = new Object();
ReadAttributes (_class, _e);
ReadClass (_class, XML_GetRootElement (_e));
if (_obj._implements(_key + TAG_NAME_LIST))
_list = _obj._get(_key + TAG_NAME_LIST);
else
_list = [];
_obj.subList += [_key + TAG_NAME_LIST];
_list += [_class];
_obj._set(_key + TAG_NAME_LIST, _list);
_obj._set(_key + TAG_NAME_TEXT, _text);
if (_iterative) break;
return _e;
function ReadAttributes (_obj, _e)
_a = XML_FirstAttribute (_e);
while (_a)
_name = XML_GetAttributeName (_a);
_value = XML_GetAttributeValue (_a);
_obj._set (_name, _value);
_a = XML_NextAttribute (_a);
function Load(_engine, _path, _actorCreator = null)
_xml = LoadXML(_engine.GetPath(_path));
if (!_xml) return false;
if (_actorCreator && _actorCreator._implements("AddActor") )
_process = _actorCreator.AddActor( _engine.GetDOS(true).GetConsole(), this);
if (!_process) return false;
return true;
}Example 1 with VR-DOS
test.pi
// XMLTest Script
// based on
class XMLTest implements DOS_Program
virtual Start()
xml_loader = new XML_Loader();
_ok = xml_loader.Load(GetEngine(), "persons.xml", this);
delete xml_loader;
End(0);
::Start();
function AddActor(console, _data)
_persons = _data.personsList[0];
for (i=0; i<sizeof(_persons.personList); i++)
_person = _persons.personList[i];
console.PrintLn("person name = " + _person.name);
if (_person._implements("propertiesList"))
_params = [];
for (k=0; k<sizeof(_person.propertiesList[0].propertyList); k++)
_prop = _person.propertiesList[0].propertyList[k];
_params += [[ _prop.name, _prop.value ]];
console.PrintLn( _prop.name + " = " + _prop.value);
console.PrintLn("");
console.Input("", null, 1);
return true;
}Example 2 with VRSCRIPT and using a Dictionary
main.pi
// XMLTest Script
// based on
class XMLTest implements GL_Program
properties:
players = []; //List of players
function Start()
delete xml_loader;
End(0);
::Start();
_params = [[ "name", _person.name ]];
players += [[ string(i), _params]];
for (i=0; i<sizeof(players); i++)
console.PrintLn("person name = " + players [string(i) ] ["name"]);
console.PrintLn("age = " + players [string(i) ] ["age"]);
console.PrintLn("gender = " + players [string(i) ] ["gender"]);
console.PrintLn("profession = " + players [string(i) ] ["profession"]);
return true;
}code included to download it as a zip file.
