Effective way to load an XML File - (II)
On a more conventional XML structure as follows
xml/stage1.xml
<?xml version="1.0" encoding="UTF-8"?>
<root name="stage1">
  <background>
    <image>Mountains_And_Sky.png</image>
    <x>52</x>
    <y>21</y>
  </background>
</root>
xml_loader.pi
We have to take care with the 'TAG_NAME_' coded in xml_loader.pi
	properties:
		TAG_NAME_LIST = "list";
		TAG_NAME_TEXT = "text";
source : viewtopic.php?f=4&t=496
test.pi
We have to use the same 'TAG_NAME_' coded in xml_loader, when the mapped object (_data) is accessed to extract the information.
// XMLTest Script
// based on
// TMX_Loader by Alberto De Hoyo Nebot
// VR-Script modifications: Javi
class XMLTest implements DOS_Program
	virtual Start()
		xml_loader = new XML_Loader();
		_ok = xml_loader.Load(GetEngine(), "xml/stage1.xml", this);
		delete xml_loader;
		End(0);
		::Start();
	function AddActor(console, _data)
			_root = _data.rootList[0];
			_name = _root.name;
			_background = _root.backgroundList[0];
			_filename = _background.imageText;
			_x 	  = _background.xText;
			_y 	  = _background.yText;
			console.PrintLn("root name = " + _name);
			console.PrintLn("filename = "  + _filename);
			console.PrintLn("x = "         + _x);
			console.PrintLn("y = "         + _y);
			console.Input("", null, 1);
			return true;
Code on ZIP :
xml_II.zip
(2.43 KiB) Downloaded 2 times
